NI TestStand
Problem writing Serial Number programatically and printing report
Labview 8.5
TS 4.0
I modified the my PreUUT sequnece to call a VI which enters a new Serial Number via a string control. This works fine.
The problem is this new SerialNumber does not seem to be accepted by TestStand and therefore does not print the reports for any executions.
(I get a "<no path>" error on the report header)
I'm using the same variables used in the standard PreUUT step.
I read a post about using RunState.Root.Locals.UUT.SerialNumber but this always causes a runtime error.
Any help is appreciated.
(3,745 Views)
Hi kevmi2ca,
check out in your PreUut Sequence that "Paramters.Uut.Serialnumber" is set to your desired s-number.
Greeings from the lake of Constance, Germany
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,741 Views)
Yes, I used a pop-up dialog to display Parameters.UUT.SerialNumber and the correct number is displayed.
(3,724 Views)
Hi kevmi2ca,
Sounds not good. Please send your PreUut Sequence (your VI is not necassary) as attachemt to this forum. I will try to run it on my maschine.
Greetings
juergen
--Signature--
(3,720 Views)
Juergen,
I got it working. It still says "no path" but I should be able to figure that out.
Thanks from Southern California!
(3,714 Views)
