NI TestStand
Editing TS specify module >> connector pane from LV
Is it possible to edit TestStands step properties >> specify module >> connector pane within LabVIEW programmatically, without opening the specify module window?
I can open module > specify from LabVIEW but, opening that window, mean you have to fill in the info your self. Smiley Indifferent
TIA
(3,029 Views)
You can access the properties via the lookup string of "Step.TS." and "Step.TS.SData".
eg to set the Mode of the 1st step in the sequence use RunState.Sequence.Main[0].TS.Mode = "Skip"
Hope this helps
Ray Farmer
Regards
Ray Farmer
(3,016 Views)
No, I was looking a way to connect connectors to variables.
eq. if I have vi with output connector named "results" and i need to connect it to TestStand FileGlobal variable named "measurement results" without using specify module screen.
(3,013 Views)
