NI TestStand
How to write the result in spread sheet file....
Hai ....
Any one help me to store the result value in spread sheet file.....
I created one sequence file which do some calculation and i want to store that result value in one spread sheet file.....
Is there any inbulit option....
I am using Test stand 3.1
(3,168 Views)
Your best bet is to use LabVIEW or CVI to do this. There are examples within the relevant application and on the NI Website for writing data to a spreadsheet.
Regards
Ray Farmer
Regards
Ray Farmer
(3,164 Views)
Rajeshg,
Just to add one other option; you can also use Active-X steps to access Excel and call macos that you create to put data into the spreadsheet. We've done this for some of our test programs, but it requires a fair bit of knowledge in Visual Basic.
-Jack
(3,154 Views)
