03-12-2008 02:54 PM
03-13-2008 06:28 PM
04-10-2008 01:27 PM
Whether I run from TestStand or LabVIEW, I get the same behavior. I did notice a couple of things though.
1) Within the VI "Full UI - Make Top-Level Window Small" (called from within the VI "Full UI - Launcher", I see the following error code
Property Node (arg 1) in Full UI - Make Top-Level Window Small.vi->Full UI - Launcher.vi
<APPEND>
Property Name: <b>Front Panel Window:Window Bounds</b>
2) Prior to running the launcher, I set the VI properties of the Top-Level VI to have a Minimum Panel Size of 1500 (width) and (Height) of 960, and a Top (25) and Left (70), so I'm not sure why I see the values I'm seeing (see WinBounds of Top Level VI Refnum in attachment).
Thoughts?
04-10-2008 02:35 PM
04-11-2008 09:14 AM
04-11-2008 09:46 AM
I'm using LV8.5 and TS4.0. I can't really post my project, as it contains some company-sensitive images/info. Is there a way we can continue this exchange (i.e. tech support) without a global post?
04-13-2008 09:12 AM
04-14-2008
12:24 PM
- last edited on
09-10-2025
10:15 AM
by
Content Cleaner
Hi mrbean,
I'm sorry but I still can't reproduce your problem. I realize you don't want to post your project on a public forum, but are you able to create a simple VI that demonstrates the problem you are experiencing?
If you'd like a more direct line of support, you will need to create a service request (either by email or phone); be sure to mention this forum thread if you decide to do so.
