11-10-2017 01:16 PM
Has anyone seen the attached error message before?
Any idea what causes it?
Note - I do not have any source control enabled within LabVIEW.
Dan
11-12-2017 12:32 AM
But do you have source control enabled within TestStand?
11-14-2017 08:27 AM
No - no SCC enabled anywhere.
I suspect this error is caused by some sort of timeout when the TSDU is trying to load LabVIEW VIs.
I am able to prevent the error from appearing by ensuring that LabVIEW is running before running the Deployment Builder.
