NI TestStand
Error 1025 When Building TestStand Deployment
Has anyone seen the attached error message before?
Any idea what causes it?
Note - I do not have any source control enabled within LabVIEW.
Dan
Dan
CLD
(3,097 Views)
But do you have source control enabled within TestStand?
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,057 Views)
No - no SCC enabled anywhere.
I suspect this error is caused by some sort of timeout when the TSDU is trying to load LabVIEW VIs.
I am able to prevent the error from appearing by ensuring that LabVIEW is running before running the Deployment Builder.
Dan
CLD
(3,041 Views)
