NI TestStand
Error: -1074118628
As a novice to NI Test Stand, I was able to develop test sequences to evaluate resistance on differents resistors and capacitance on capacitor setting up the proper limits using NI PXI-4072 from NI PXI-1045. Using NI PXI-2575 Multiplexer, I was able to test individual sequence using the proper route without any issues. However, when the sequences are combined in one main sequence, resistors tests failed and capacitor test yielded to error, namely Error code: -1074118628. Since I am using multiple test sequences, are there options that I should be used that would facitilate my test?
JR
(3,345 Views)
JR,
Do you have any error messages from TestStand? Can you send a screenshot? Is the error always in the same place?
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(3,317 Views)
