NI TestStand
Error -17,502v only appears sometimes. Passing data by a struct.
Hello and good day. Sometimes this message appears to me when the system that I have is running. "-17502; System Level Exception".
In my TestStand sequence that step correspond to a CVI function call.
Basically, what that step function does is receive a int as an input, search some data in a database and then return some information passing it by a struct.
In TestStand I created a Custom Data Type to match the information that I need to receive from my DLL.
This is the structure that I have in myDLL:
This is the Custom Data Type that I created:
And in the end of my function, this is how I am sending the information:
This errors appears only sometimes, and is not constant. I tried to replicate it running my sequence a lot, but does not appears when I want it to appear.
In another topic
( http://forums.ni.com/t5/NI-TestStand/passing-a-structure-by-reference-into-a-dll-cvi-get-s-an-error/... )
they said it could appear because a bad definition of the data type, but I really thik I am doing it correctly.
Any ideas about what could be happening?
Thanks in advance.
Message 1 of 1
(3,283 Views)
