Error -18002 on LabVIEW with RunTime Engine
Good morning everyone, I have a TestStand 2020 sequence in which, within a loop, I call two VIs: one in which I write via I2C using an FPGA, and a second one in which I send the ‘Write&Read’ command.
When I run the two VIs from LabVIEW 2021 or TestStand with ‘LabVIEW Development’ selected as the adapter, everything works correctly.
However, when I run the sequence with the LabVIEW Runtime Engine as the adapter, it only works on the first iteration; on the second, it freezes, giving me error -18002: ‘VI was aborted’.
The two VIs are very, very similar (only the command sent to the FPGA changes), so I don’t understand why the error occurs.
If it helps, I open and close the FPGA reference each time using ‘Open FPGA VI Reference’ via the bitfile and ‘Close FPGA’. How can I resolve this? It’s not an insurmountable problem, but it would be better to be able to use the sequence with the Runtime Engine for stability reasons.
(363 Views)
Check the path of the bitfile you use for open ref, I bet the file can't be found since the Runtime Path differs from the one in the dev environment
(360 Views)
Thanks for your reply, but I don’t think that’s the issue: I’m passing the full path, so it shouldn’t depend on whether it’s running with the runtime or not, should it? Besides, if that were the case, all the VIs where I use the bitfile should have the same problem, but they all work correctly (even that one, albeit only on the first iteration of the loop)... which is why I don’t understand
(301 Views)
