11-02-2004 05:05 AM
11-03-2004
06:36 PM
- last edited on
10-20-2025
03:57 PM
by
Content Cleaner
Hey Joe,
Do you get this error with any sequence or just the first step of your sequences. One suggestion would be try a very simple sequence with one step that calls 1 VI without any subVIs.
Are you running the sequence from the sequence editor, the LabVIEW operator interface or some other environment? If you're running it from the LabVIEW operator interface you should use the TestStandLVGUIRTS activeX server. The following KnowledgeBase gives more information:
Do I Need to Compile My LabVIEW VIs called from TestStand into Executables when Distributing My Test System?
Have you seen the following knowledgebase? From your post it seems you've tried these
suggestions already but you may want to double-check.
Why Do I Get Error -18002 "VI is not executable" with TestStand?
If you're concerned about efficiency then you might want to try LabVIEW DLLs. Please refer to the following knowledgebase:
Can I Improve TestStand Performance by Using LabVIEW DLLs instead of LabVIEW VIs?
11-03-2004
06:37 PM
- last edited on
10-20-2025
03:57 PM
by
Content Cleaner
Hey Joe,
Do you get this error with any sequence or just the first step of your sequence. One suggestion would be try a very simple sequence with one step that calls 1 VI without any subVIs.
I hope this helps!!
Sarah Miracle
