NI TestStand
Error -19034 Cannot Call Distribution VIs
While on the TestStand deployment, the deployment tool work fine and created  the Distribution files, for  a particular one it gives me this -19034 error. when attempting the build. The help advises to Repair the TestStand installation, which I did, but problem persists.
From the picture I am attaching, this particular Build VI Distribution 2010 - TestStand.vi highlighted in yellow-ish does not exist in the ...\TestStand 20XX\Components\Tools\Deployment Utility\TestStand - Build VI Distribution.
My wondering is why would it look particularly for it in this deployment I am trying to build, and not for other deployments? Folder architectures are similar and nothing out of the norm when it comes to additional selected installer (Run-times).
Does anyone have a clue of what this is. Help's suggestion seem broad and not helpful.
Thanks.
JR
(2,239 Views)
Hi JR,
It seems like your issue is similar to one of our previous forum posts. Take a look at it and see if those troubleshooting steps work for you!
https://forums.ni.com/t5/NI-TestStand/Deployment-utility-error-quot-VI-not-executable-quot/td-p/2729...
Megan T.
Technical Support Engineer
(2,158 Views)
