NI TestStand
How to continuously run a sine wave signal through a DAQ in teststand for multiple steps?
I want a sinewave to be applied to a DAQ channel for an entire sequence and stop at the end of a sequence. How do I do this?
(2,395 Views)
If you're using LabVIEW, you can create a step called Run VI Asynchronously.  You could call this VI in MainSequence setup and then it could constantly read a TestStand variable to know when to stop.
Similarly, you call your DAQ code in a sequence and then call the sequence in a new thread.  This sequence would run in parallel with your other sequences.
(2,141 Views)
