NI TestStand
Error -2147467259 when using API to Logout
I'm using the Teststand API to call Login and Logout from LabVIEW. The login process works correctly and I am able to read the current user information after a succesful login, but when I call Logout I receive error -2147467259 which has a description of:
0x80004005) Unspecified error.
NI System Configuration: Miscellaneous operation failure.
Message 1 of 1
(815 Views)
