NI TestStand
Sequential Model: Tile Sequences called into a new execution
I was wondering if it was possible to tile sequence called to run in a new execution, is it possible to tile these new execution windows, similar to what the batch does.
I hope that makes sense.
I am calling Sequence A in an CallSequence Step to Run in New Execution.
I am calling Sequence B in a CallSequence Step to run in a New Execution
They both run in an ew execution, and each have there own execution window, as a tab. Is it possible to tile these windows?
Kev
(1,290 Views)
Just wanted to add to this, I would settle for away to programmatically set "New Vertical Tab Group" when I start my sequence in a new execution
Kev
(1,251 Views)
Are you thinking of running / tiling the executions in SeqEdit?
(1,242 Views)
Thanks for the reply. That correct I'm planning in running the Sequence Editor and tiling in there, if possible
Kev
(1,227 Views)
Hi Kev,
I am not aware of a method to manipulate SeqEdit from a TestSequence, sorry.
(1,218 Views)
Accepted by topic author kross8
SOLVED!!
Putting this here to help others.
There is a UIMessage that does what it says on the tin.
  • UIMsg_TileWindows–(Value: 23) Post this message to the user interface to instruct it to tile the windows the activeXDataParam parameter specifies. Use an array of ActiveX reference objects that reference a PropertyObjectFile or an Execution for the activeXDataParam parameter. The user interface tiles the windows that correspond to the objects in the array. To tile all windows, pass a NULL reference for the activeXDataParam parameter or use the Nothing keyword if you are using the ActiveX/COM Adapter.
Hope this helps
Kev
(1,198 Views)
Hey Kev,
Awesome, you dug into this
thanks for sharing this!
Oli
(1,188 Views)
