NI TestStand
Error 2705
        i encountered error 2705 when installing the TestStand 2024. Previously l was using TestStand 2019 in Wins 11. Can anyone help me with this? Thanks
(1,503 Views)
Accepted by topic author Ryan8225
Also related to https://forums.ni.com/t5/NI-TestStand/Encountered-error-when-installing-TestStand-2024/td-p/4445873
Since you are seeing multiple errors on the insatllation, would you provide some more information on  your system configuration?
I suspect, TS 2019 is already installed?
With regards to error 2705.... is it possible, TestStandVresion selector was running in the background?
(1,487 Views)
Thanks for ur help. i go to Version Selector to active my current version, after that the error no more already.
(1,469 Views)
