NI TestStand
Error executing Steptype "-17601:Attempted to load a module for a step whose module has not yet been specified
I create  à custum steptype to stop the execution of my sequnece but th steptype generate an run time error .
Have you some explication?
Message 1 of 15
(4,020 Views)
Accepted by topic author RchB
Not sure why you are seeing that error.  I reproduced your step type and it seems to work fine.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
Message 2 of 15
(4,004 Views)
One more thing:  Instead of using the ActiveX post step substep maybe try doing a default Post-Expression: RunState.Execution.Terminate()
jigg
CTA, CLA
testeract.com
Message 3 of 15
(4,002 Views)
I have already done that but it not working i have the some error
Message 4 of 15
(4,000 Views)
Hello jigg
i used your step type it work.
i compared betwen step type is the some configurations but i don't know why mine it not work
thanks
Message 5 of 15
(3,998 Views)
Does yours work if you make a new instance of it?  It almost seems like it is hanging on to some older instance.
jigg
CTA, CLA
testeract.com
Message 6 of 15
(3,992 Views)
yes its works
Message 7 of 15
(3,986 Views)
Hello Jigg
i want to change the terminate steptype by à break point in my user interface with API teststand .
have you an idea?
Message 8 of 15
(3,982 Views)
See Attached for both.
jigg
CTA, CLA
testeract.com
Message 9 of 15
(3,980 Views)
Thanks its work, but when I Re-play  the sequence, it generates an error
Message 10 of 15
(3,976 Views)
