NI TestStand
Error, [-29017]The channel specification string contains invalid characters or could not be understood. [Error Code: -29017, User-defined error code.]
I am not sure if this is the right board for this question, my appologies if its not I am getting this intermittent error when running one of teststand sequences. Could someone shed some light on where I should be looking> I know its not the sequence as it worked prior to upgrading the NI software but not sure what is not working correctly. Many thanks in advance Antony Drkins
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(3,684 Views)
Can you post a screen shot of the dialog panel that displays the error?
What NI software did you upgrade?
What versions of the software were you running?
The error code is discribed as user-defined error code, what is you code module interface to (hardware, software etc)?
Regards
Ray Farmer
Regards
Ray Farmer
(3,683 Views)
Thanks for your reply Can you post a screen shot of the dialog panel that displays the error? will do next time it occurs What NI software did you upgrade? upgraded from lv6 and ts2 to lv7.1 and ts3.5 as well as switch,dmm,scope etc... What versions of the software were you running? The error code is discribed as user-defined error code, what is you code module interface to (hardware, software etc)? will find out for you Hopefully will post the rest of the info soon
(3,680 Views)
A little bit more information, when the fault does occur it is when the dmm (ni-4070) is taking a voltage reading.
(3,674 Views)
Hey Antony,
Have you seen the problem in a while?  Let use know when you can get a screen shot of the error and the text of the error message.  Have a good day!
Best Regards,
Software Engineer
Jett R
(3,612 Views)
