NI TestStand
Getting Steptype of a step at runtime
Is it possible ( in TestStand 3.1) to get the steptype of a step during runtime? I want a add some specific handling a all steps of a steptype in the PostStepFaiureCallback .
(3,071 Views)
Hi Markus,
Try
Step.StepType()
StepType.Name(), this will return the name of the steptype eg "PassFailTest" for a Pass/Fail Test step type.
Regards
Ray
Regards
Ray Farmer
(3,069 Views)
You can also use the expression function TypeOf() to return the same information.  For instance, I made a message popup with the following expression as the message, and it displayed "MessagePopup"
TypeOf(Runstate.Step)
Josh W.
Certified TestStand Architect
Formerly blue
(3,054 Views)
