NI TestStand
Error ActiveX. Develop. vs Base Deployment Engine. Urgent
Hi !
I get a ActiveX error when i'm running sequense a 'Base Deployment Engine' enviroment.
When i'm running same sequense a TestStand[TS] 'Development' enviroment it works fine.
So where is a problem?
(1,261 Views)
Are you testing the different license options using the same machine?
The error indicates an error generated when TestStand is trying to create an COM reference to of LabVIEW development System.
The error should not be related to TestStand's license. You either do not have LabVIEW development system installed or there is an issue with its's license.
Hope this helps.
Anand Jain
NI
(1,214 Views)
I make a TestSystem software. And i my Aim is spread it globally with out 'Full development' enviroment. Reason of cost. So i m running same software(TS running a LV.vi   :s) with out LV and TS Full development enviroment. Only i install Needed "Base Deployment Engine" to TS.
So what is problem?                    (i'm still checkin m LV code....)
(1,195 Views)
