NI TestStand
Error: Aufgerufener ist ungültig. [Error Code: -17502, System Level Exception.]
Hi!
Im trying to control an installed software package for a camera over an activeX-Server.
I have chosen a couple of methods and integrated it into the teststand sequence over the TestStand ActiveX Adapter. So far so good.
Now, there are a couple of methods, which work properly... but theres one problem:
My Problem: I got one method, which is unfortunatly responsible for reading out measurement data. I dont have to say that this is an essential function for me. This method doesnt work.
I call the Method and give it some proper parameters. After that the following error occurs:
Its the German Version of TestStand. I guess it means that "the called one isnt valid, Error Code -17502 System Level Exception"
I have to admit that Im not really experienced in working with the activeX adapter.
I made a screenshot in the attachement below.
HELP!!!!!!!!!!!!!!!!!!!!!
Andy K.
(3,941 Views)
Hi Andy,
What are the parameters for iGetStandardStatistic ?
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,929 Views)
There are three integer parameters to overgive to the method and 6 real-number parameters which are given back from the method. So the parameters aren't so complicated.
Furthermore I found out the following:
In the Problem described above I tried to call the method over the TestStand ActiveX Adapter.
Meanwhile I tried to create an LabView VI in which I overgive the ActiveX Reference and do the job over Invoke nodes... Surprise!Surprise! It worked.
So I found a solution for the problem, but I can't explain and I definitely dont know why it doesnt work with the ActiveX Adapter
What can be the problem?
greetings
andyk
(3,924 Views)
Maybe you have the wrong reference to your ActiveX Adapter step.
Maybe you can post a small example
regards
Ray Farmer
Regards
Ray Farmer
(3,918 Views)
TS stores Numbers as double (8Bytes)
If you are using int, char or float TS will cast automatically
BUT if your Method is using a variant can not cast !
See this thread: http://forums.ni.com/ni/board/message?board.id=330&message.id=24860&query.id=1109895#M24860
Please post a screenshot of the ActiveX Module settings.
Regards
Juergen
--Signature--
(3,904 Views)
