NI TestStand
what is the class reference that has to be specified for the first step of sequence file if there is no object to specify
I am creating the sequence file dynamically.The issue is "What has to be specified in the Object reference field ?" for the first step in the sequence file if there is no object to apecify.
I am using Singleton Class in .Net. So I need not create object in TestStand. The Get property of the class will return its own class object. So the Class Reference should be empty only.When I choose the property manually, I am getting this error. This I am getting only when I create this step through C# TestStand APIs. Please help me to remove this error in the Class Reference field using TestStand APIs.
The error that is showing is  "The expression should not be empty".
(3,544 Views)
This seems to be a similar question to this one
Is it?
Regards
Ray Farmer
(3,537 Views)
Hi Ray,
Hi Jeff,
Or maybe this one ??
http://forums.ni.com/ni/board/message?board.id=330&message.id=27613#M27613
regards
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,513 Views)
@op Please stick to a single thread for better response..... people might not know to which thread a reply is required......
(3,482 Views)
