07-11-2005 03:54 AM
07-13-2005
03:00 AM
- last edited on
08-15-2026
12:29 PM
by
Content Cleaner
Hello Capblans,
You will found, in the link below, document that explain the error and gives solution:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019ToqSAE&l=en-US
Sanaa T
National Instruments France
Sanaa T.
07-13-2005 03:23 AM
Thank you very much. But it's already set and it didn't work. And I have not the part of the message " Class not registered", I have only "System Level Exception. Error code: -17502".
I work with TestStand 3.1.
07-18-2005 07:16 AM
Hi!
Now I have this error (System Level Exception) a first time after 26 occurences, a second time when TestStand run Clean Up and try to close the SQL Statement.
After this if I try to run the sequence the error appears at the beginning at the first access to a table of the database.
I have to close and restart TestStand to be able to run the sequence.
07-19-2005 12:12 PM
07-19-2005 12:15 PM
07-19-2005 03:12 PM
To Capblans -
It is unclear as to how you are accessing the data from the database. Some questions are:
07-20-2005 02:17 AM
Hi!
1- I use a database MySQL.
2- I use an ODBC Driver, the last version.
3- I access the data within the sequence.
4- I use TestStand step types to access data.
5- The step consist on get the data in the database where the index equals the increment.
6- The Statement is "GET 'nommod1' FROM 'nomtest' WHERE ID_test = Locals.increment"
07-20-2005 02:38 AM
Hi!
Thanks! But can you explain how be sure that I am freeing all handles that you allocate when I have done with them?
capblans
07-20-2005 03:29 AM
I'm sorry I made a mistake for the point 6, the correct SQl request is :" GET 'nommod1' FROM 'nomtest' WHERE index=Locals.increment" index is not a field.
