NI TestStand
Error While Using InsertElements
The sequence attached (InsertElementsError) creates array (Loop.Param1 & Loop.Param2) using InsertElements.
InsertElements creates-
  • Param2 with 3 elements, which is correct
  • Param1 with 3 elements, when it should had been 4 elements.
(1,168 Views)
Hello InduKhatri,
I hope you are well and safe!
Could you please provide more information? I don't understand what your question is.
If you can attach some photos will be great. Also, which version of TestStand do you use?
Best Regards,
Edgar Umrikyan.
(1,043 Views)
