NI TestStand
Error code -40 while creating distribution - .NET framework 2.0
While creating a TestStand distribution, I get this error:
*** Error: Internal error. (Error code -40)
There was a problem getting information about the source distribution for product 'NI .NET Framework 2.0 Language Pack x86 Installer'
*** End Error Report
*** WARNING ***
Skipping deployment information for an unidentified product because error code -40 occurred while loading file: C:\Program Files\National Instruments\Shared\MDF\Manifests\NI .NET Framework 2.0 Language Pack x86 Installer {F8ECD2D6-659C-49EB-8454-5F8F7B526FCF}.xml
*** WARNING ***
The .xml file exists and the distribution builds but why am I getting this error?
Message 1 of 18
(6,189 Views)
While building a different distribution, I get these additional errors:
*** WARNING ***
Product 'NI Remote Provider for MAX' depends on a product that cannot be found on the system. ID of missing product: {B5171839-26E3-48D9-9FD6-AF7F39055146}
Product 'Broker Aux 8.2' depends on a product that cannot be found on the system. ID of missing product: {B5171839-26E3-48D9-9FD6-AF7F39055146}
*** WARNING ***
Aren't these products supposed to be copied to the Product Cache?
Message 2 of 18
(6,182 Views)
Hi Ching-Hwa Yu,
Do you receive the same error if you start with a new sequence file and follow chapter 14 in the TestStand Reference Manual? If you are receiving this error regardles of what you are trying to build it will be a different situation then if it only occurs when trying your current build.
Ryan T
Message 3 of 18
(6,150 Views)
Message 4 of 18
(6,141 Views)
Hi Ryan,
I receive the first error regardless of what I am trying to build.  If I create a blank distribution and have no workspace selected and only the TestStand engine, this error will occur.  In the Installer Options, I have only LabVIEW 7.1.1. RTE and LabWindows/CVI 2009 RTE selected in the components to include since they are required by the engine.  Even if I uncheck "Include .NET Framework Version 2.0 in Installer", this error occurs.  I have already tried all of the other suggestions in the the forums such as deleting everything out of the product cache.
For the second error, I have already tried deleting everything out of the Product Cache.  It could be that I need to include the hardware configuration however I cannot test that at the moment.
I'm on Windows 7, TS 4.2.1
Message 5 of 18
(6,129 Views)
I've narrowed the second error down further.  It only occurs when I include either NI-VISA Configuration Support 4.6.2 or NI-CAN 2.6.3.
When searching the registry, the ID of B5171839-26E3-48D9-9FD6-AF7F39055146 appears numerous times as the Data in UpgradeCode keys of other IDs.
What is missing?
Message 6 of 18
(6,121 Views)
Ching-Hwa -
I have reproduced the first error that you mentioned and will look into it further. I'm still working on reproducing the second error. I'll let you know if I have further information or questions.
Manooch H.
Message 7 of 18
(6,002 Views)
Ching-Hwa -
Could you please tell me exactly which errors you are currently receiving when you attempt to deploy? After clearing the ProductCache's, do you still receive the errors:
Error -40: NI .NET Framework 2.0 Language Pack x86 Installer
as well as the
I look forward to hearing back from you.
Manooch H.
Message 8 of 18
(5,948 Views)
Hi Manoosh,
Thanks for looking into these errors.  Yes, after clearing the ProductCaches, I still receive the errors.
For every deployment I attempt, I always receive "Error -40: NI .NET Framework 2.0 Language Pack x86 Installer".
The other two errors only appear if I include NI-VISA Configuration Support 4.6.2 or NI-CAN 2.6.3 as part of the deployment.
Please let me know if that is not clear.
Message 9 of 18
(5,944 Views)
Ching-Hwa -
In my testing to reproduce these errors, I've been able to at least reproduce the first error. To resolve it, I had to repair my DriverDVD installation. Would you please try going to Add/Remove Programs (on Windows XP) or Programs and Features (on Windows Vista/7) and try to repair one of the NI drivers you have installed (I recommend DAQmx). This should prompt a repair of the DriverDVD.
This repair could take some time so you might want to start it when you will be able to walk away from your desk for a bit. This resolved the first error for me and another customer so I'm hoping it resolves the error for you as well.
Please let me know how it goes.
Manooch H.
Message 10 of 18
(5,898 Views)
