08-10-2010 05:48 PM
I have a simple requirement. I have to call Notepad.exe and send some key strokes from Teststand. I downloaded an example from NI webiste. The example works fine if i call in Labview. If i call the same VI from Teststand, it does not work. I think the problem is getting the Notepad window to focus.
Also i tried setting the "Show Front Panel WHen Called". It works sometimes. But i don't want the front panel window to show. I have attached the example i downloaded.
09-07-2010 01:31 PM
duplicate post:
