NI TestStand
How to pass Array Collection to Test Stand?
I'm trying to pass collection object (ArrayList) from C# application to TS. I  have assigned output value in TS to Container, but while the sequence end executing, then occured an error: "Specified value does not have the expected type".
What should I do to get full access to my ArrayList? To what kind of variables type I should assigned ArrayList?
Thanks for help anyway.
piotr
(4,078 Views)
If your collection is derived from System.Collections.Generic you are not able to use because generics are not supported with TS 4.2 or earlier.
You need a wrapper class.
If possible you can signup for TS 4.5beta.
See also this thread:
http://forums.ni.com/t5/NI-TestStand/How-to-iterate-though-a-net-dictionary/td-p/1232557
Hope this helps
juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(4,073 Views)
But ArrayList is  from System.Collection Library. Is it possible to use it in TS? I also have to work with TS 4.2.
Thanks for reply
(4,069 Views)
Accepted by topic author piotrsteczkiewicz
Hi ,
It should work if you use ObjectReference instead a Container
Check out this simple example
Regards
Juergen
--Signature--
(4,049 Views)
Thanks very much. This is the exactly answer what I was looking for.
Your example helps me a lot.
Thanks very much again!!
piotr
(4,029 Views)
