Calling "Move Window To Top.vi" Does not work if called from Teststand
I have a simple requirement. I have to call Notepad.exe and send some key strokes  from Teststand. I downloaded an example from NI webiste. The example works fine if i call in Labview. If i call the same VI from Teststand, it does not work. I think the problem is getting the Notepad window to focus.
Also i tried setting the "Show Front Panel WHen Called". It works sometimes. But i don't want the front panel window to show. I have attached the example i downloaded.
(3,107 Views)
duplicate post:
http://forums.ni.com/t5/NI-TestStand/Calling-quot-Move-Window-To-Top-vi-quot-Does-not-work-if-called...
Al B.
Staff Software Engineer - TestStand
CTA/CLD
(3,034 Views)
