Error during loadind 32-bit .net dll by 64-bit TestStand
During sequence development when I wanted to call 32-bit  .net dll I came across an error.
The DLL is a 32-bit DLL and thus cannot be loaded by 64-bit TestStand.
Could not load file or assembly 'xxx' or one of its dependencies. An attempt was made to load a program with incorrect format.
What options I have to successfully cal this module?
(6,199 Views)
Accepted by MimiKLM
You cant mix 32 bit and 64 bit DLL.You need to recompile the DLL with any CPU options ( since its a dotnet dll) or a 64 bit DLL.
Hope this helps.
Ravi
(6,194 Views)
Ok,
I'ce compiled the module once again for both platforms.
Now works under TS x32 and x64.
(6,186 Views)
