NI TestStand
Error during loadind 32-bit .net dll by 64-bit TestStand
During sequence development when I wanted to call 32-bit  .net dll I came across an error.
The DLL is a 32-bit DLL and thus cannot be loaded by 64-bit TestStand.
Could not load file or assembly 'xxx' or one of its dependencies. An attempt was made to load a program with incorrect format.
What options I have to successfully cal this module?
(6,195 Views)
Accepted by topic author MimiKLM
You cant mix 32 bit and 64 bit DLL.You need to recompile the DLL with any CPU options ( since its a dotnet dll) or a 64 bit DLL.
Hope this helps.
Ravi
(6,190 Views)
Ok,
I'ce compiled the module once again for both platforms.
Now works under TS x32 and x64.
(6,182 Views)
