Error executing substep 'GetchannelValue'
Thanks in advance to anyone who can shed some light on this (even if just to confirm it to be a TestStand bug).
Firstly, I'm running TestStand 2014 service pack 1 when ever executing sequence file which includes Channel value limit test getting run time error.
i.e Error executing substep 'GetChannelvalue'
An error occured while calling .NET member 'GetsingleChannelvalue';Object does not match target type.[Error code: -17500]
(3,547 Views)
What Step Type is Read Engine Speed?  It looks like you have a custom step type and the sub step isn't set up correctly.
jigg
CTA, CLA
testeract.com
(3,530 Views)
Read Engine Speed type is Normal channel value limit test
(3,521 Views)
the same steps seq works properly on the other computer. So not able to figure what's the exact issue
(3,517 Views)
Accepted by Venugopal
Because that step type is installed by VeriStand and is obviously built on top of some .NET objects I think you should make sure that you are using the same version of VeriStand and .NET on both machines and that you installed the add on correctly.
I don't have VeriStand and haven't really used it so I can't test anything out for you. sorry.
jigg
CTA, CLA
testeract.com
(3,514 Views)
Thanks dude.
I will try to uninstall and re-install teststand package .And will update the result
(3,511 Views)
Not the TestStand package.  The VeriStand package needs to be checked.  HUGE difference.  VeriStand has an add-on that installs some TestStand steps.  That step type you are using is created by VeriStand and NOT TestStand.  I doubt this is a TestStand issue.
jigg
CTA, CLA
testeract.com
(3,508 Views)
