NI TestStand
Error executing substep 'GetchannelValue'
Thanks in advance to anyone who can shed some light on this (even if just to confirm it to be a TestStand bug).
Firstly, I'm running TestStand 2014 service pack 1 when ever executing sequence file which includes Channel value limit test getting run time error.
i.e Error executing substep 'GetChannelvalue'
An error occured while calling .NET member 'GetsingleChannelvalue';Object does not match target type.[Error code: -17500]
(3,541 Views)
What Step Type is Read Engine Speed?  It looks like you have a custom step type and the sub step isn't set up correctly.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,524 Views)
Read Engine Speed type is Normal channel value limit test
(3,515 Views)
the same steps seq works properly on the other computer. So not able to figure what's the exact issue
(3,511 Views)
Accepted by topic author Venugopal
Because that step type is installed by VeriStand and is obviously built on top of some .NET objects I think you should make sure that you are using the same version of VeriStand and .NET on both machines and that you installed the add on correctly.
I don't have VeriStand and haven't really used it so I can't test anything out for you. sorry.
jigg
CTA, CLA
testeract.com
(3,508 Views)
Thanks dude.
I will try to uninstall and re-install teststand package .And will update the result
(3,505 Views)
Not the TestStand package.  The VeriStand package needs to be checked.  HUGE difference.  VeriStand has an add-on that installs some TestStand steps.  That step type you are using is created by VeriStand and NOT TestStand.  I doubt this is a TestStand issue.
jigg
CTA, CLA
testeract.com
(3,502 Views)
