NI TestStand
Error when build .NET from labview
Hello All,
I have labview 2010.   I encounted a build errror with juat a simple VI that has a 1D array output as below.   Pleas tell me what I did wrong
Error 1172 occurred at Error calling method NationalInstruments.LabVIEW.VIParser.VIParser.SetVIInformation, (System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation.
    Inner Exception: System.IndexOutOfRangeException: Index was outside the bounds of the array.)
Possible reason(s):
LabVIEW:  A .NET exception occurred in an external assembly. For information about correcting this error, copy the following exception (in bold), and search the Microsoft Developer Network (MSDN) Web site or the Web for a possible explanation.
System.IndexOutOfRangeException in AB_Engine_InteropAssembly_ProtoDefined.vi->AB_InteropAssembly.lvclass:Build.vi->AB_Build.lvclass:Build_from_Wizard.vi->
AB_UI_Frmwk_Build.lvclass:Build.vi->AB_UI_FRAMEWORK.vi->AB_Item_OnDoProperties.vi->AB_Item_OnDoProperties.vi.ProxyCaller
(4,186 Views)
Any one can help please
Tphan
(4,166 Views)
Sounds like you have an index out of bounds in an API your VI is using. What is AB_UI_FRAMEWORK? This does not sound like it has anything to do with TestStand. You might try posting to the LabVIEW forums.
-Doug
(4,161 Views)
Uh oh..
sorry I thought i post in the labview forum
(4,157 Views)
