NI TestStand
Whenever I Use "ON the Fly Logging"
I am currently using Teststand 2010 and I am getting the following error (See Picture) everytime I use/enable the "On the fly Logging". Maybe you might be able to see what is going on. I do not know why I am getting the error maybe the forum can share some insight
(3,404 Views)
You cannot and should not log results from a callback other than MainSequence.   That error usually means you are trying to log a step from a callback other than MainSequence.  You need to figure out which step is causing the error and then turn off reporting for that step.
Hope this helps,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,401 Views)
