NI TestStand
Evaluate function in teststand status expression
I can not understand the meaning of function Evaluate() in below sentence,and can not find the explanation in help files,could someone help me ?
Step.DataSource != "Step.Result.PassFail" ? Step.Result.PassFail = Evaluate(Step.DataSource) : False, Step.Result.PassFail ? "Passed" : "Failed"
Message 1 of 8
(11,714 Views)
Lets assume In this case step.datasource has a variable stored ex "locals.num"
The function Evaluate(Step.DataSource) does the following :
Get the variable name stored in step.datasource i.e. locals.num
Return the data stored in locals.num
Message 2 of 8
(11,705 Views)
Thank you!
this expression  means below,but I am not clear that the "false" means, means do nothing?
if(Step.DataSource != "Step.Result.PassFail" )
else
false
if(Step.Result.PassFail )
passed
else
failed
Message 3 of 8
(11,678 Views)
The step status i.e. step.result.passfail is set to either pass or fail by the expressions.
Slighty modified your steps :
else
Step.Result.PassFail = false
Step.Result.PassFail=passed
else
Step.Result.PassFail=failed
Message 4 of 8
(11,674 Views)
Sorry,I am still not clear.
as you said,if Step.DataSource == "Step.Result.PassFail" (the default value of pass/fail step), then Step.Result.PassFail = false, then Step.Result.PassFail=failed,then the step fail. it seems wrong, Step.Result.PassFail should be valued by the output parameter.
Message 5 of 8
(11,667 Views)
Accepted by tanggio
Sorry to confuse you.
Hope the explanation helps.
if(Step.DataSource != "Step.Result.PassFail" )  // True if user has selected a different data source ( by default its step.result.passfail)
Step.Result.PassFail = Evaluate(Step.DataSource)  // Get variable stored in step.datasource.Read the value and store in step.result.passfail
else
false   // Dont do anything when default data source is present
if(Step.Result.PassFail )  // It will have the latest value either by default or even if data source is changed.
passed  //status is set as passed
else
failed  //status is set as Failed
Message 6 of 8
(11,662 Views)
Thank you,now I'm clear.
Message 7 of 8
(11,645 Views)
As an added point of reference, we use the "Evaluate()" function to to parse Variables in a Step Name for TestStand steps.  This makes our steps very readable and FAST to code in TestStand.
For example our tests to communicate to a device might be to write a value to a value to a specific parameter, such as writing a Setpoint Value.  So the TestStand step name would look like:
[] Write:Setpoint(1)=200
    Where Setpoint is the Parameter Name, (1) represents the Instance, and 200 is the value written
However we use the Evaluate() function to parse out variables:
Locals.sParameter = "Setpoint"
Locals.nInstance = 1
Parameters.nValue = 200
[]Write:{L.sParameter}({L.nInstance})={P.nValue}
   (We use a shortened version of L. for Locals., P. for Parameters., etc. because it doesn't take up so much space on the Step Name)
We have a library subsequence (Check for Curly Brackets to be parsed) that parses out any variables that are enclosed in the {} curly brackets.
  Replace "L." with "Locals.", etc. and then parse out the variables in the Pre-Expression,
and then EVALUATE the variables in the Post-Expression:
Locals.sTemporary ="RunState.Caller.RunState.Caller."& Locals.sVariable,
'If the variable exists, resolve it, if not replace it with '{ERROR}' and continue.
Locals.sTemporary =( PropertyExists(Locals.sTemporary)? Evaluate(Locals.sTemporary)  :"{ERROR}"),
'Put the resolved variable (or error) back in place of its name
Locals.sWorkingString = Locals.sBeforeVar & Locals.sTemporary & Locals.sAfterVar
Also, during runtime, if there happens to be an error in the StepName, we can edit it and continue on using a "Set Step Name" tool.
Mike
Message 8 of 8
(11,638 Views)
