NI TestStand
EvaluateEx function does'nt work properly if the first parameter passed is "0"
I have a function where I have used EvaluateEx function.
I am checking a condition, if that is zero, my code will be as below:
m_po = obj->EvaluateEx ("0", 0);
If I pass parameters in the above way, the function does'nt work properly. But if I pass "0.0" instead of "0", then it works. I wanted to know the reason. If any one knows the answer, please reply.
(2,929 Views)
When you say the function does not work properly what do you mean?
Does the function returns a valid object reference?
Is the object value 0?
I was not able to reproduce the problem. It would really help If you could post a simple example.
Regards.
Antonio Lie.
(2,924 Views)
