NI TestStand
Evaluation Software Silkscreen
We loaded a deployment on to a system when the license was unavailable so we activated an evaluation license. A few days later while the temp license was still active we activated the real Base Deployment license. However some of the LabVIEW dialogs still display National Instruments LabView Evaluation Software in a light overlay.
How do I make this go away?
jvh
(3,423 Views)
It sounds like you still have an evaluation license for LabVIEW activated.
(3,416 Views)
It expired.
(3,409 Views)
You'll either need a valid LabVIEW Development license (if you want to continue to be able to edit VIs on that system), or configure TestStand to use the LabVIEW Run-Time Engine as its adapter instead.
(3,394 Views)
Hi jvh75021,
The Base Deployment license has nothing to with LabVIEW.  It only lets you deploy and execute TestStand sequences. If you would like the ability to modify VIs on your deployment system for debugging purposes, than a debug deployment license is the best option.  Aside from that, if you don't need to modify the VIs on your deployment machine, than using the runtime engine as suggested is the best option.
Hassan Atassi
Senior Group Manager, Digital Support
(3,377 Views)
