NI TestStand
Execute any Sequence
Is there a possbility to run any sequence from a sequencefile? The following Method doesn't work:
Engine.NewExecution(sequenceFile, "Sequence1", modelfile, false, 0, null, null, null);
Is the only way to create Execution Entrypoints in Processmodel?
(3,028 Views)
Its should do providing you dont run with a process model file.
Engine.NewExecution(sequenceFile, "Sequence1", null, false, 0, null, null, null);
Regards
Ray Farmer
Regards
Ray Farmer
(3,023 Views)
