NI TestStand
html report is not saved when sequence files are called from CVI application
Hi all,
When I call a sequence file from an application developped in LabWindows/CVI the HTML report as configured in the model file is not saved to disk. If I open the same file in TestStand and do execute -> Test UUT's, the HTML is saved correctly. I checked the sequence files use the model i specified.
Can anyone give me pointers to information or gotcha's i should look out for?
I'm using TestStand 3.5 and LabWindows / CVI 8.0.0 (273)
Any help is much appreciated.
T.i.a. & regards,
Dagget
(3,316 Views)
How are you calling the execution of the sequence file in your application?
Regards
Ray Farmer
Regards
Ray Farmer
(3,285 Views)
I have found the answer, but I waited with a reply before I had tested it. But here follows the solution:
I called the sequence file from an operator interface I had developped using LabWindows / CVI 8, using the function as below.
It turned out I was calling the sequence file directly without using the proper model. I changed this to calling the Test UUTs sequence and supplying the model in the function call. The function you see here makes calling the model or a single sequence an option by setting the input parameter useModel.
static HRESULT i32_SendTestStandSequence( int useModel )
    char *modelDesc = NULL;
    CAObjHandle modelSeqFile = 0;
    HRESULT hresult;
    char sequence[MAX_LEN_PATH + MAX_LEN_SEQNAME] = "";
    if ( useModel ){
        TS_SeqFileGetModelSeqFile(gMainWindow.start_sequence, &errorInfo, &modelDesc, &modelSeqFile);//get handle of process model
        strcpy( sequence, "Test UUTs" );
    } else {
        modelSeqFile = 0;
        strncpy( sequence, s_IniVars.ac_StartSequence, MAX_LEN_PATH + MAX_LEN_SEQNAME );
    // See teststand helpfile under Sequence -> executing
    hresult = TS_EngineNewExecution( gMainWindow.engine,            // engine
                                    &errorInfo,                     // errorinfo
                                    gMainWindow.start_sequence,        // handle sequence file
                                    sequence,                         // sequence name
                                    modelSeqFile,                    // handle process model
                                    VFALSE,                            // breakAtFirstStep
                                    TS_ExecTypeMask_Normal,            // executionType
                                    CA_DEFAULT_VAL,                 // sequenceArgs
                                    CA_DEFAULT_VAL,                    // editArgs
                                    CA_DEFAULT_VAL,                 // interactiveArgs
                                    &gMainWindow.CurrentExecution );// handle executionObject
    return hresult;
This works for me.
Dagget
(3,283 Views)
I had a feeling that is what your problem was, glad you have it working.
Regards
Ray Farmer
Regards
Ray Farmer
(3,280 Views)
