NI TestStand
Error -18005
I have a test sequence that runs well with the TestStand 3.5 sequence editor.
But if I run the same test sequence from a LabVIEW 8.0 User Interface of my own (that calls TS), I got the following error:
Error: Parameter 'VisaRessRef (OUT)':
Failed to convert a TestStand type to a LabVIEW type or vice versa. [Error Code: -18005, Failed to convert a TestStand type to a LabVIEW type or vice versa.]
I get this when a VI called by TestStand returns a VisaRessRef (of type LabViewIOControl in TS) to my UI.
If run another test sequence that contains only MsgBox and Wait from my UI, everything works well also.
BTW: I looked in TS: Configures => Adapters... => LabView => Configures , and "Reserve Loaded VIs for Execution" is checked.
Can somebody help?
Yves
(4,556 Views)
Hey Yves,
There was a known issue with VISA I/O nodes (VISA resource name controls) inside a typedefined cluster used through the connector pane of a vi when interacted with from a TestStand step when the LabVIEW adapter is set to use the run-time engine.  It gives the 18005 error.  This is with TestStand 3.5 and LabVIEW 8.0.  It has been fixed in the most recent patch of LabVIEW (8.0.1).
Pat P.
Software Engineer
(4,542 Views)
Pat
Can you confirm that this Error 18005 issue has been resolved becuase I am seeing exactly the same behavious with LabVIEW 8.0.1 and TestStand 3.5
I've also tried LabVIEW 8.20 and I still get the same problem. Only solution I can find is to revert to LabVIEW 7.1 but that is no longer an option for me due to some recent code changes. Looks like I am stuck executing the sequence using the full LabVIEW installation.
Anybody got any ideas ?
Regards
Chris Roebuck
Filtronic Broadbdand Ltd
(4,438 Views)
You should probably post a simple sequence that reproduces the problem so that the Application Engineers can examine it.
(4,433 Views)
I believe the suggestion that James gave will be the quickest way to troubleshoot the problem.  If you could post a small sequence that exhibits this error, I can try and take a look at it here and see what might be causing this error to pop up.
Pat P.
Software Engineer
(4,422 Views)
Is the VISA reference valid?  In LabVIEW 8.0 and later, LabVIEW started reporting an error if the VISA reference is not valid (which can happen if the reference was never opened) whenever TestStand tries to read it when using the LabVIEW Run-Time Engine.
Try opening the reference before passing it to TestStand.
(4,414 Views)
That's it !
Opening the VISA reference fixes the problem when using the RTE in versions of LV > 8.0
Chris
(4,391 Views)
