03-31-2006 02:45 PM
04-03-2006
10:00 AM
- last edited on
07-15-2025
04:09 PM
by
Content Cleaner
Hey Yves,
There was a known issue with VISA I/O nodes (VISA resource name controls) inside a typedefined cluster used through the connector pane of a vi when interacted with from a TestStand step when the LabVIEW adapter is set to use the run-time engine. It gives the 18005 error. This is with TestStand 3.5 and LabVIEW 8.0. It has been fixed in the most recent patch of LabVIEW (8.0.1).
08-15-2006 07:55 AM
Pat
Can you confirm that this Error 18005 issue has been resolved becuase I am seeing exactly the same behavious with LabVIEW 8.0.1 and TestStand 3.5
I've also tried LabVIEW 8.20 and I still get the same problem. Only solution I can find is to revert to LabVIEW 7.1 but that is no longer an option for me due to some recent code changes. Looks like I am stuck executing the sequence using the full LabVIEW installation.
Anybody got any ideas ?
Regards
Chris Roebuck
Filtronic Broadbdand Ltd
08-15-2006 10:50 AM
08-15-2006 11:28 AM
08-15-2006 11:55 AM
08-17-2006 03:46 AM
That's it !
Opening the VISA reference fixes the problem when using the RTE in versions of LV > 8.0
Chris
