NI TestStand
Export LV output into 2 variables
I want to export a LV output to 2 Teststand variables like this:
Locals.Text, Step.Result.ReportText
But Teststand export the LV output only in the last variable.
Is it not possible to export LV outputs in more than one variable?
Kind regards
Matthias
(2,836 Views)
You can only export to one variable.  If you need multiple copies, consider using a Post-Expression, like Locals.Text = Step.Result.ReportText.
(2,824 Views)
