NI TestStand
Exporting/Loading properties for Multiple Numeric steps
So, my test uses quite a few 'Multiple Numeric' test steps.
I am just looking at using the property loader to import all of these limit values.
Now as i understand each test step in the property file (excel im y case) must have multiple columns (for each index in the data array)
I also understand that the easiest way to generate the excel properties file is to export it before adding the values.
Now, I am using the 'tools - import/export properties' window, and i try to add Step.Result.Measurement[x].Limits.Low but it is not available.
There is an entry for Step.Result.Measurement[?].HighExpr, so i can add that, then change it to [0], [1] etc
Is there not a way to add all of the array items at once?
I need '.comp' '.Limits.Low' '.Limits.High' for each array element.
Have i missed something obvious?
Labview 2010, TestStand 2010
(3,472 Views)
No you haven't missed something obvious. I dont believe this has change in any way of the various TestStand version.
What version of TestStand are you using?
Regards
Ray Farmer
(3,457 Views)
Hi, I;m using 2010.
I'll give a more specific case:
In one of my multiple numeric tests i have the limit expression : Step.Result.Measurement["ck1+"].Limits.High
(I even tryed removing the alias and using : Step.Result.Measurement[0].Limits.High)
This can be found in the expression browser tree.
But this does not appear in the tree of expressions when using the properties import/export window.
The only items that do are: Result.Measurement[?].Limits.LowExpr Result.Measurement[?].Limits.HighExpr
i have tried manual editing entries there, but they are ignored when exporting.
Help
(3,454 Views)
Just for the record, i solved this.
Bascially my misunderstanding of how the limit expressions are entered.
I have tried to put the expression e.g Result.Measurement[?].Limits.Low into the limit expression for that step and then export to properties file.
It seem the correct way is to leave the limit as a numeric and then the Step.Result.Measurement[?].Limits.Low be available in the import/export properties window. Just change each [?] to the array index & repeat.
(3,411 Views)
