NI TestStand
differences between the two methods?
Usually,I use paralel method, but advantatges of serial method?
Thxs !!!
(3,364 Views)
Either is exceptable but you should capture the error message returned the TS API calls.
Regards
Ray Farmer
(3,358 Views)
Hello Oriol,
If you are concerned about code performance, both are similar because you are using a sequential ActiveX communication between LabVIEW and TestStand, so at the end LabVIEW is sending sequential messages to TestStad Engine even if you program VIs in parallel.
(3,231 Views)
