NI TestStand
Expression as function parameters using API
I'm creating TS sequences from text scripts, using the CVI API.
I usually affect values to step properties using functions like TS_PropertySetValNumber(...) but now I need to affect an expression to a function call parameter, like FileGlobals.Var1.
I cannot affect this expression to the step type property because the expression can be different between two steps instances.
Is there any function that can use to do that directly?
I attached an picture of what I want to change.
Any help would be welcome.
Thanks.
Stephane
(3,065 Views)
Have you looked into Evaluate() ?
CTA, CLA, MTFBWY
(3,027 Views)
