NI TestStand
create report
I hope can you help me. I'm a newbie of teststand and I have got a problem with him. In sostance I have a multi steps which generates a list of results. I need that the values are inserted in the test report, but with the order that I want. I've seen in the most post in the forum, that I modify the Model Process or the resultList but I've any idea like makes.
Francesco
(3,051 Views)
The order of how the results are displayed on the report is based on the limits you create in the Limits tab of the Multiple Numeric Limit Test step.
CTA, CLA, MTFBWY
(3,023 Views)
Hello Francesco,
I found two different links related to your question, I don't know if I understood correctly, could you please take a look?
Changing the TestStand Parameter Order in the Report
http://digital.ni.com/public.nsf/allkb/26B6921DE07B47FB8625756900761A92?OpenDocument
Why Are the Results of Subsequences Called in New Threads Not Included In My Report?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MKjSAM&l=en-US
Is any of these what you were looking for?
Antonios
(3,021 Views)
