External Reporting Solutions
Hi
Does anyone know of an external reporting solutions to generate a report similar to the teststand reports?
Help share your knowlegde
(2,981 Views)
Not sure what you are going for here Shako?
One of the main purposes of using TestStand is it's built in reporting capabilities.  I would suggest not using TestStand if you are going to recreate it externally.
It gives you 4 different formats for reports: HTML, XML, Text and ATML.  If those aren't enough it allows you to write to databases using about any provider out there.  In addition you can format the XML reports using 3 different style sheets: Horizontal, Expand and Report.  All of these are customizable to the fullest extent.
Can you elaborate on your scenario and then I may be able to help you find a better solution?
jigg
CTA, CLA
testeract.com
(2,967 Views)
Thanks for the reply.
Well i disabled the reports after a test, only if a report is need it must be read out of the database in a formatted way.
Teststand does not cater for this and hence my question.
Im looking for a way to read the information out of the database and display it to the user in a formatted way?
It would be great if teststand add a sequence to recreate a report  using the UUT Result as reference.
I have posted this under Exchange Ideas.
(2,955 Views)
might the following be of interest
http://zone.ni.com/devzone/cda/tut/p/id/3739
Regards
Ray Farmer
(2,953 Views)
