11-08-2011 04:52 AM
Hi
Does anyone know of an external reporting solutions to generate a report similar to the teststand reports?
11-08-2011 12:30 PM
Not sure what you are going for here Shako?
One of the main purposes of using TestStand is it's built in reporting capabilities. I would suggest not using TestStand if you are going to recreate it externally.
It gives you 4 different formats for reports: HTML, XML, Text and ATML. If those aren't enough it allows you to write to databases using about any provider out there. In addition you can format the XML reports using 3 different style sheets: Horizontal, Expand and Report. All of these are customizable to the fullest extent.
Can you elaborate on your scenario and then I may be able to help you find a better solution?
11-09-2011 12:03 AM
Thanks for the reply.
Well i disabled the reports after a test, only if a report is need it must be read out of the database in a formatted way.
Teststand does not cater for this and hence my question.
Im looking for a way to read the information out of the database and display it to the user in a formatted way?
It would be great if teststand add a sequence to recreate a report using the UUT Result as reference.
I have posted this under Exchange Ideas.
11-09-2011 01:50 AM
might the following be of interest
http://zone.ni.com/devzone/cda/tut/p/id/3739
