NI TestStand
FileGlobal usage
How to find out whether a particular FileGlobal variable has been used in the sequence file or not? Is there any API for that? Otherwise what could be the best algorithm for doing the same?
(3,242 Views)
You can use Windows Explorer search facilities and set the Search for text in a file.
I think in TestStand 3.5 and above you should beable to do a Find "a given text" in a sequence file.
Regards
Ray Farmer
Regards
Ray Farmer
(3,231 Views)
