NI TestStand
Post action Terminate doesn't work
1)  Can somebody please explain the following:
I set a step of type NONE as follow:
in the pre expression I write ---  Step.Result.PassFail = False 'FAIL
In the post action I write --- On Fail - Terminate execution
Obviously the test fails but surprisingly it doesn't terminate.  Why is that?
2) I would like to show a message (upon pre-condition) and to terminate after it is displayed.  Is there a short way to do it (preferably in the same message step...)
(3,489 Views)
Hi Rafi2003,
1) That should be working, as you expect.   What TestStand version are you using?
2) You could have you post action jump to a location, or call a sequence with you message and then have the post action of the message step do the terminate.
Regards
Ray Farmer
Regards
Ray Farmer
(3,484 Views)
