Flow control - How to use select case
Hi.
I thought I should check out the select/case flow control steps in TS 3.1. Does anybody know how to define one case for more than one option? I want to set up the case as the example in VB shows:
dim i
i = "One"
select case i
case "One", "Two", "Three"
Regards
Tom Andres Lomsdalen, CTD
(6,823 Views)
Accepted by TomLomsdalen
Hi Tom,
This functionality is not possible.  You may want to use an If/Else If/Else structure to combine your cases.
Allen P.
NI
(6,762 Views)
Have you any answer for this.
I'm having a problem like this. But Have not been able to make it work.
I'm using TS4.1.1
This is working.
Selsect
Case 1
case 2
case3
End select
 Thins is not.
Select
case 1,2
case 3,4
end Select:
 Please help me if you have some advice
(6,328 Views)
Answered here.
(6,319 Views)
